My neighbor Paul has an 84 or 85 944 NA that won't start.
It cranks He replaced the battery, the coil and the fuel lines. He thinks it must be electrical. He last drove it months ago. It rarely comes out of the garage. Is there a common reason specific to 44's for this. Kind of like the DME relay in a 911? Any thing he should try to narrow it down? He's handier than me. All assistance is appreciated.
Hunt 611racing.com OG Racing Team Vimeo https://www.youtube.com/user/Streak986 1999 SPB #611 2004 Wrangler “That’s how people like you work. Your ego is so out of whack that it will do what ever it can to protect itself. And people with a messed up ego can do these mental gymnastics to convince themselves they’re awesome when really they are just douche bags” - Kyle, South Park "If you need to focus maybe you should buy the book and take it home" - MLIN |
DME Relay does go bad. If memory serves, it is harder to get to on the early cars than the late ones.
He replaced the coil, but what about the distributor and rotor? Has he checked for spark beyond the coil? What fuel lines did he replace? There are a lot of them. There are lots of reasons why a 944 won't start.
John P. 1994 968 - DD 1984 944 NA - Low income housing for mice / Lemons Car Past: 1986 951 - sold 1987 944 S2 Conversion - sold 1989 944 NA - sold 1986 944 NA - donated |
Here are 944 starting problems that I have seen:
1. crank position sensor worked its way loose/bad connection 2. CPU had bad connection (wiggled and plugged in harness) 3. DME Relay
Jim 1986 Porsche 944 Turbo |
First.....He should check to make sure he's getting spark at the spark plugs using a tester.
That's an easy way to eliminate "spark" as a problem. If the DME relay is bad, then the fuel pump won't come on and the engine won't get any fuel. On Clarks Garage, there is a procedure for making a jumper that will bypass the DME relay. It's easy to make and worth keeping in the glove box, just in case. If that works, and the car starts, then the DME relay is probably bad. Here's a link: http://www.clarks-garage.com/pdf-manual/fuel-05.pdf
Jim B. Maryland 1987 944S - Black #303 - Zeus Suit Racing 2007 Boxster S - Carrara White - Daily Driver "Life is too short to have a boring car" |
He should shoot it....
Donnie 1974 911-sold 1995 BMW M3-GTS2 2001 Excursion diesel tow beast |
Put it on CL for $500?
Sounds like he went replacing parts.. were they warranted or just tried as being the culprit. Certainly need to check fuel rail for pressure and plugs for spark. DME relay is pretty cheap iirc and a spare should always be on hand. It wasn't mentioned, but when parked several months ago did it work?
does it have gas...
Good info. I'll pass this along.
It did run a few months ago. Thanks
Check the wires on the cap. It won't run if they are hooked up in the wrong order.
