New tool thread - Page 32 - Dorkiphus.net
Old 07-11-2022, 05:57 PM
slbates's Avatar
slbates slbates is offline
slbates
I just purchased on of these on sale from SWAG. I agree with Ed, it works well.
Originally Posted by edevinney View Post
The Swag portaband stand is surprisingly good. It's nothing like having a real stationary band saw, but works great for small wood and metal. The 1/8" plate legs and bent 3/16 top are sturdy, and what at first looks like a hokey attaching mechanism works surprisingly well.
Steve
996 GT3
996 C2 (gone)
911SC (gone)
Old 02-19-2023, 04:14 PM
GEARWRENCH 1/4" Drive 90 Tooth Long Handle Teardrop Ratchet 6" - 81028T
I'm a sucker for a nice ratchet. This little thing feels good in hand and the action is very smooth.
Old 02-19-2023, 06:38 PM
To save others a few seconds: https://www.gearwrench.com/products/...drop-ratchet-6
Looks like a nice tool.
1999 Miata ("SM") race car
Old 02-20-2023, 02:29 PM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
I bought this little guy out of frustration and it has proven its worth.
https://www.amazon.com/dp/B08D6YDQNH...roduct_details
I was working on the wife's Audi A3 to replace a servo motor on the HVAC system that had crapped out and air was not going where it needed to. The servo in question was way up in there and attached with two torx bit screws. It was impossible to get anything thicker than about an inch on the screw. This little fella allow you to put just the torx bit in it making it nice and thin. By holding it with your thumb and middle finger and with your ring finger in the loop on the end and your little finger outside, it won't slip out of your hand and you can get enough torque on it to loosen the bolts. Once loose, the thumbwheel is used to loosen the screw quickly. Same for reinstallation since the ratchet can be reversed with the lever. Great little tool for working in tight spaces. Comes with a 1/4 socket adapter as well.
89 944 Turbo Race car
98 993 C2S w/Aerokit II
70 Boss 302
86 Mustang SVO
08 F250 SD Diesel
15 Audi SQ5
Old 04-26-2024, 10:24 PM
Default This looks handy!
https://www.amazon.com/AGM-Products-...4184364&sr=8-3
Looks like a nifft6 idea for a DIY project too.
Old 04-27-2024, 09:42 AM
Nerfbar's Avatar
Nerfbar Nerfbar is offline
Nerfbar
Attachment 67878
If you need help to keep it up.
Barry
18 Carrera cab
15 Macan S
Old 04-27-2024, 04:17 PM
Geeze Barry, it sounds like your offering.
- 2024 is the year, beeches...
Old 04-29-2024, 10:51 AM
dnwong's Avatar
dnwong dnwong is offline
dnwong
Default Cheap Welding
So, I wanted to learn to do some welding and there are a lot of cheap welding equipment on amazon.
I bought this guy on sale for $48 bucks a few weeks back.
https://www.amazon.com/dp/B0B2QQW3WZ...t_details&th=1
Have not even opened yet since I don't have any other accessories like (helmet, gloves, etc).
Before I go any further, what do you think about these?
Dudley
Aldie, VA
99 996 C4 Black/Black Areo
86 951 Graphite / Burgundy
2002 BMW 530i
2008 Volvo XC90
1995 Chev Astro (workhorse going-bald)
My Garage Build
Old 05-01-2024, 11:16 AM
Goggles Paesano's Avatar
Goggles Paesano Goggles Paesano is offline
Where's the beef?
Goggles Paesano
These are nice lightweight welders. If you never welded before, be prepared for a serious learning curve. Just to get the arc going is a process, then to actually make a use-able weld. You will be able to do it, just don't really expect it to go well at first unless you are really gifted. Get some stock/practice material and practice. If you are planning to use this to work on auto body sheet metal, it will really be a struggle to not burn through. But, I used my for lots of jobs and it works great once you get used to it.
Turning good track cars into other people's headaches since 1990
Denis Jenkins (PCA'86)
95 318ti S54
97 318ti S52
95 M3 S54 vin 00067
87 RX7 ITS
02 330i
98 328i
71 911T
70 Karmann Ghia,
96 f350 7.3
available
Gone
4 356's,1 996, 4 911's, 1 912, 2 Boxster S, 5 914's, 3 944's, 3 951, 1 924S, 3 95 m3, 03 M3,95 Ti/CS. 97M345, 84 rx7chump car, ITB gti 21, ITB GTI 48, 89 325is s52,07 Z4 coupe, 69 Charger General Lee, 2 66 Cadillac verts, 1 68 cadillac vert, and many many others
Old 05-04-2024, 05:21 PM
alw20147's Avatar
alw20147 alw20147 is offline
alw20147
It really depends on what your welding needs are. If just to learn, then the arc/stick welding capability be fine for regular carbon steel up to 1/8-3/16. As the tig function, touch/scratch start is very hard to do and if learning, you will spend more time restriking an arc than focus on tig techniques.
Does that unit accept gas? if not the tig welds will need excessive heat for it to fuse/melt together and will be very porous. I failed my welding tech cert 2x due to porosity - gas pressure too low the first time and lack of penetration - heat too low the second. Luckily third time was a charm.
I find myself gravitating to the mig for most mild steel and the tig for stainless and aluminum.
Al W.
2001 911 cab
