#51
And precise differential:
![]() Regards Andrew |
#52
Next about 550 MW power engine project:
550 MW . Efficient are better if all "cylinders " make ceramic coating ( simile Shuttle Regards Andrew |
#53
Old other post:
![]() New rod differential at animations Solid Works when one axle stop: http://www.new4stroke.com/differ%20stop.wmv Andrew |
#54
And GIF animations :
#55
I find a beautiful array :
![]() At last something happens . In my oscillating dynamo I help cellular telephone IC Lm 2621. May be cellular telephone need advanced mechanic?? If put in cellular telephone mechanic automatic movement,using in mechanic clock, and miniature electric generator drive it, we don't need charge cellular telephone.Phone will be loaded on our result of traffic, obvious as there will be in our pocket Some parts and principle work of automatic movement: ![]() ![]() ![]() ![]() ![]() Perhaps, we must use e.g. 6 such systems, in order to can be charge phone goods .? Same philosophy : no one big , many little. May be Swiss precision it will astonish again . Regards Andrew May be Swiss precision it will astonish again . My propose for yacht: On highest point of mast instead of flag,for example,box belongs to place with such array: 20 pcs X 20 pcs X 60 pcs systems (50 cm x 50cm x 30 cm). All 24000 system's. And I think, so enough for made electric energy for yacht. Without any fuel. Last edited by Feliks; 09-07-2008 at 05:38 AM. |
#56
Feliks - do you have a running engine that can actually work and take the abuse of use? If so can we see videos? Do you have dyno information? There are many people that have the resources to help make these things a reality but you need to take a step and either make a running model that can take abuse or show us that you have done that. Word of mouth is powerful.
#57
There is possible build closest house fiberglass mast too and we insert dynamo in this highest place. When wind blows this e.g 15 meter mast too have some movement.
Without barrier for birds , and no sound effect. And looks better Andrew |
#58
Andrew, have you seen the fantastic contraption site?
http://www.dorkiphus.net/porsche/showthread.php?t=18122
We will now use the power of the Continuum Transfunctioner to banish you to Hoboken, New Jersey. BMW Spec E46 #609 |
#59
My propose new
Differential Gear. It's first design. ![]() Without any cogged gear, and if we will employ oiled lubrication solid ball bearing (closed), then work is possible without oil oiling .Polyurethane HD belt. I am some, that such will work without that noises differential . Regards Andrew Thanks Rob in VA |
#60
My friend ( architect and musician) has said that it distrusts springs." Because if it can crack, then sometime it will crack sure." I agre with his think:
![]() And my vision Pack of oscillating dynamo: ![]() Regards Andrew |
